63 Heater Blower Motor Problem - NCRS Discussion Boards
  • Joe S.
    • July 31, 1999
    • 319
    My blower motor works on the slow speed, but if I turn the knob to the second or third position, there is nothing. Where should I be checking?
    My late 63 has both the main connector coming into a capacitor then to the blower motor. There is a separate ground wire going to a spade on one of the outer screws. I checked the switch as well as the connector to the reostat on the back of the inner heater box but still nothing happening. This is with the car cold and not running.
    Any suggestions I had to nail this down? Note that this is a newly restored motor and I just reinstalled it and hooked up the wires. I could have done something wrong ;-)
  • Geoff C.
    • May 31, 1979
    • 1613
    Ck blower mtr resistor mounted in inner box *NM*
    • Wayne W.
      • April 30, 1982
      • 3605
      Re: Ck blower mtr resistor mounted in inner box
      The gound for the heater motor and the wipers are both on a black wire to the starter bolt. Lots of times people dont get it hooked back up when they do motor work.
      • Joe S.
        • July 31, 1999
        • 319
        Ground is hooked to the starter. IS there a test procedure for the resiter? I'll check the FSM again but I didn't see one when I went thought it before.
