How/what do you use to refinish the "sandstone" inner grill area on a 71?
refinishing front grill on a 71
Re: refinishing front grill on a 71
(1) Clean off the existing paint.
(2) Mask to match the old paint lines.
(3) Shoot a coat of self-etchant primer (SEM makes a variety of colors in spray cans; also available from the Eastwood catalog if you can't find locally) so the replacement paint will actually stick to the underlying chrome.
(4) When dry, shoot a final coat of the correct color/texture paint. Terry McManmon has posted the source/color code once or twice before--search the archives...- Top
I usually save this sort of info.
Attached Files- Top
It may be worth while hunting up the rest of that thread. There was some additional information by way of feedback. Be patient because the server change may affect the search function.Terry- Top
Re: follow up
Here's the other info I had. I don't know if a direct search for a topic can be done. Or if there is addittional info posted.
Attached Files- Top
