If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
The block number on this engine is 3892657,
It has solid lifters, a 4-barrel holly carb, domed pistons.
Does anyone know what horsepower the engine is?
Also what is the gap for adjusting the valves on this engine?
David - the block is a correct 67 number, and from what you describe it sounds like it should be a 327/350 HP engine. It should have an aluminum intake manifold ending in 490 on the casting, but it should not have solid lifters....they were not used in 67. If you give the suffix code on the block stamping we can help you more....Craig
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
