58 C1 4:11 Posi clunks in turn
  • Ken Susnjara
    #1
    My 58 worked fine until the left rear wheel bearing went out. Changed the bearing and now the posi clunks in a tight turn. Also inside tire squeels when you accelerate in a turn from a stop. Manual says perhaps wrong fluid but that dosen't make sense. Same fluid as before. Any ideas? Could I have done something wrong when changing the bearing? Any help is appreciated. Thanks.
  • mike mccagh
    Re: 58 C1 4:11 Posi clunks in turn
    drain read end gear oil, replace with limited slip diff gear oil and add 4 oz of posi addative. bet the problem leaves .probably coincidental that the axle bearing crapped out about the same time. good luck, mike
    • Ken Susnjara
      Thanks Mike, I'll give it a try.
      • Clem Z.
        • January 1, 2006
        • 9427
        also find a large parking lot a do slow figures "8s" to get the lube into the plates
        • Ken Susnjara
          Just as a postscript, I changed the fluid, put in the additive and made a series of left and right turns and it woked great. Problem gone and thanks again for the help.
