C2: Rocking seats - NCRS Discussion Boards
C2: Rocking seats
  • Mark F.
    • March 1, 2002
    • 174
    C2: Rocking seats
    Both buckets seats in my '65 rock back and forth about 1/4". Which parts are prone to wear to cause this?
    Thanks for your input.
    Mark
  • Scott G.
    • August 31, 1984
    • 132
    Re: C2: Rocking seats
    I had this issue in my 66. The problem was a loose bolt which secures to seat track to the floor. These bolts kept loosening due to rusted undersized threads in the plates mounted under the floor.
    • mike mccagh
      besides scott's input, the ball bearings in the seat track often wear. not an easy fix. good luck, mike
      • Mark F.
        • March 1, 2002
        • 174
        Thanks for the info. *NM*
        • Scott Butville
          I don't think the seat tracks with roller bearings were used until '67. You probably have the tube within a tube type which has some replaceable parts. However, that did not completely eliminate the problem in my '64. I ended up buying repro inner tubes from Miguel Delgado at 60's Corvette Seats which are a few thousandths larger than originals which solved the problem.
          • Joe C.
            • August 31, 1999
            • 4598
            Mark:
            The seat tracks slide via 1/4" dia. x 2" long coil springs (4 per track), which are installed laterally within the tubular track. These act as the bearings. They are very sturdy, and if one splits/breaks, it will usually cause the track assembly to bind, not become loose. Most likely, the seat adjuster rod is not fully engaging the slots on the track, and causing "slop" . Check the cam's engagement on the inner side of the track rail.
            Joe
