Experts: I have a 66 L-36, 40,000 org miles. Engine sits in the car as it left the factory. I have my baby into my trusted mechanic repairing my Holley Carb. Further check indicates that I have 1 LB of fuel pressure going into my carb. Bought new, correct # fuel pump and put on car. Same reading. My mechanic is perplexed with far more engines showing too much fuel pressure rather than 1 LB on two different pumps. Lines checked from the tank, steady nice stream of fuel coming out of line however once into mechanical pump, same 1 LB pressure that I'm told should be 4-5 LBS. Mechanic feels it is likely my CAM, fuel lobe is gone, however his experienced ear tells him the rest of the CAM sounds fine but why the low fuel pressure. In the interim I'm looking at putting on a electrical fuel pump........to buy me some time and $$$$.
Question: In your experience does it sound like the right diagnosis or are we missing something, is there a way to test to see if the CAM fuel lobe is gone w/out pulling everything apart?? ANy other thoughts as to why LOW FUEL PRESSURE??
Much appreciated......
