70 L-46 thermostat coil - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Need to replace mine. Like most other confusion with the 70 350 differences, heres the part numbers from the catalog:
    69 y(350) (exc, sp.h/per)--- 3946093
    69-70 y(350) (w/sp. h/per)------ 3887148
    70 y(350) (exc. sp.h/per)----- 3973497
    I think that 3973497 is the correct piece for the 70 L-46.
    However, I listed the 69 applications because there are two listed for the only two 350's in 69. The base engine and the L-46. Neither use a Holley. I assume from the 69 info that 3946093 is for the base engine, and 3887148 is for the 69 L-46. But since that application also lists as 1970, wouldn't that make it for the 70 L-46 as well? Then the 3973497 would be a base 70, 350. Problem with that logic is that there then is no application for the (sp. h/per) 1970.(LT1)
    Throwing all that out the window, and going with my first thought, I think that maybe the 3887148 is the Holley,(LT1) piece. Could be the 1969 is only referenced because the LT1 was supposed to be a 69 option. That would make all the pieces fit. Also the base and L-46's would have the same piece. The easiest way to tell I guess is the Q-jet pulls down, the Holley pushes up, right? I just don't know which does which
    Geez, all I want to do is get a thermo coil!
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 70 L-46 thermostat coil
    Dennis I have the 70 base engine 350 and I replaced the thermostatic coil many years ago. I have been looking for the replaced part that I put in the box the new part came in so I could see what the part number was, have only gone through 4 boxes so far. Have not found it yet. Your post got me curious as to what part the Chevy parts counter person sold me. I don't know if GM still services the coils, have you checked?
    • Dennis D.
      • March 1, 2000
      • 1071
      Jim
      As far as I know they do not.
      I also have a GM box that one had come in. Although you have a head start in the search, I'll join in the hunt.
