67 parts numbers and intake question - NCRS Discussion Boards
  • larry linkous
    Looking for correct numbers for the following 67 Corvette 427/400HP, A/C, A.I.R. smog, and T.I.: 1 Fan 2 Fan clutch. 3 Radiator shroud 4 Water pump Also I have a 3894382 tri power intake that is dated 9-15-67, car was building in early April, is that correct??. Also noted that my original A/C hose's are marked 66 as in 1966. Seems they must have had a lot of parts on the bin and used them up?? Thanks Larry
    Re: 67 parts numbers and intake question
    Larry -
    If the car was built in April, 1967, it wouldn't have an intake manifold that was cast five months after the car was built; if that intake is dated 9/15/67, it's a service replacement, cast early in the 1968 model year.
    • larry linkous
      John Wrong intake date!!
      Intake is 9-15-66 not 67. Thanks Larry
