The front pass. rotor on my 67 has excessive runout (.0085) and a thickness of only 1.160. So I assume replacement is in order.
1. Is there any special way to drill out the rivets holding the rotor to the hub.
2. Can anyone recommend a vendor for the replacement rotor?
3. Does the new rotor need to be riveted to the hub? Who does this if needed?
Thanks for the help.
Larry
Larry
