Just finished putting my 63 together and took it for a test drive yesterday. HAve a one things to work out but for the most part no major problems. One annoying thing that is bugging me though is the accelerator is sticking with the engine holding about 2500rpm. If I disconnect the accel rod the engine returns to idle with no problems. If I move the accel with my hand, it seems fine and has little or no drag on it. It has a little drag with the ground strap hooked up, but doesn't seem like enough to stop the rod from returning.
If the return spring were just a little more stout I think it would work perfectly. But the spring installed was part of the FI unit rebuild and I would hate to either shorten it or replace it with something stiffer.
Anyone experience this or have a suggestion for a fix. It's not good for the rebuilt engine and also not the safests setup.
Thanks...
Joe's 63 FI Convertible
Thanks...
