Hello,
I am going to be doing a tech seminar at our next NCRS Chapter meeting. A fellow member needs to replace the fuel tank in his '67 coupe which will be the subject of the the tech siminar. I have replaced fuel tanks in C2 before, but the cars have all had either side exhaust or the undercar exhaust was removed for replacement and the tank changed at the same time.
My question is this. Can the fuel tank in a coupe or convertible be changed without removing the mufflers? I have a 4-post drive on lift so access to the underside of the car will be no problem. Since this is going to be a club meeting activity, I'm trying to limit the amount of time it will take to do the replacement. If the mufflers need to be taken off I just need to allow some time before the meeting starts to get to the point where the tank is ready to be removed.
James West
Omaha, NE.
James West
Omaha, NE.
