427 Cam Shaft - NCRS Discussion Boards
427 Cam Shaft
  • Keith McVay
    427 Cam Shaft
    I am building a 1966 427(425hp) Corvette, I need to know what the factory lift and duration is for the cam shaft?
    • 15610
    Re: 427 Cam Shaft
    L-72 CAMSHAFT
    Part number 3863143 and 3904362
    Lift data from Chevrolet drawing numbers 3863144 and 3904366
    Tappet lift, inches, measured from point of maximum lift in cam degrees
    OE indexing points of maximum lift: Inlet 108 deg. ATDC, exhaust 120 deg. BTDC (see notes)
    INLET AND EXHAUST LOBE
    OPENING
    Angle Lift Velocity Acc. x 10 Jerk x 100
    0 0.30572 0.000000 -0.001800 0.000000
    1 0.30563 0.000180 -0.001800 0.000000
    2 0.30536 0.000360 -0.001800 0.000000
    3 0.30491 0.000540 -0.001800 0.000000
    4 0.30428 0.000720 -0.001800 -0.000125
    5 0.30347 0.000900 -0.001775 -0.000375
    6 0.30248 0.001075 -0.001725 -0.000375
    7 0.30132 0.001245 -0.001700 -0.000125
    8 0.29999 0.001415 -0.001700 0.000000
    9 0.29849 0.001585 -0.001700 0.000000
    10 0.29682 0.001755 -0.001700 0.000000
    11 0.29498 0.001925 -0.001700 0.000000
    12 0.29297 0.002095 -0.001700 0.000000
    13 0.29079 0.002265 -0.001700 0.000000
    14 0.28844 0.002435 -0.001700 0.000000
    15 0.28592 0.002605 -0.001700 0.000000
    16 0.28323 0.002775 -0.001700 0.000000
    17 0.28037 0.002945 -0.001700 -0.000125
    18 0.27734 0.003115 -0.001675 -0.000375
    19 0.27414 0.003280 -0.001625 -0.000375
    20 0.27078 0.003440 -0.001600 -0.000125
    21 0.26726 0.003600 -0.001600 0.000000
    22 0.26358 0.003760 -0.001600 -0.000125
    23 0.25974 0.003920 -0.001575 -0.000375
    24 0.25574 0.004075 -0.001525 -0.000375
    25 0.25159 0.004225 -0.001500 -0.000125
    26 0.24729 0.004375 -0.001500 -0.000125
    27 0.24284 0.004525 -0.001475 -0.000375
    28 0.23824 0.004670 -0.001425 -0.000375
    29 0.23350 0.004810 -0.001400 -0.000125
    30 0.22862 0.004950 -0.001400 -0.000125
    31 0.22360 0.005090 -0.001375 -0.000375
    32 0.21844 0.005225 -0.001325 -0.000375
    33 0.21315 0.005355 -0.001300 -0.000250
    34 0.20773 0.005485 -0.001275 -0.000375
    35 0.20218 0.005610 -0.001225 -0.000375
    36 0.19651 0.005730 -0.001200 -0.000250
    37 0.19072 0.005850 -0.001175 -0.000500
    38 0.18481 0.005965 -0.001100 -0.000875
    39 0.17879 0.006070 -0.001000 -0.001000
    40 0.17267 0.006165 -0.000900 -0.001000
    41 0.16646 0.006250 -0.000800 -0.001000
    42 0.16017 0.006325 -0.000700 -0.001000
    43 0.15381 0.006390 -0.000600 -0.001000
    44 0.14739 0.006445 -0.000500 -0.001125
    45 0.14092 0.006490 -0.000375 -0.001500
    46 0.13441 0.006520 -0.000200 -0.001875
    47 0.12788 0.006530 0.000000 -0.002000
    48 0.12135 0.006520 0.000200 -0.002000
    49 0.11484 0.006490 0.000400 -0.002000
    50 0.10837 0.006440 0.000600 -0.002000
    51 0.10196 0.006370 0.000800 -0.002000
    52 0.09563 0.006280 0.001000 -0.002000
    53 0.08940 0.006170 0.001200 -0.002000
    54 0.08329 0.006040 0.001400 -0.002125
    55 0.07732 0.005890 0.001625 -0.002500
    56 0.07151 0.005715 0.001900 -0.002875
    57 0.06589 0.005510 0.002200 -0.003000
    58 0.06049 0.005275 0.002500 -0.003000
    59 0.05534 0.005010 0.002800 -0.002750
    60 0.05047 0.004715 0.003050 -0.001875
    61 0.04591 0.004400 0.003175 -0.000750
    62 0.04167 0.004080 0.003200 -0.000125
    63 0.03775 0.003760 0.003200 0.000000
    64 0.03415 0.003440 0.003200 0.000000
    65 0.03087 0.003120 0.003200 0.000000
    66 0.02791 0.002800 0.003200 0.000000
    67 0.02527 0.002480 0.003200 0.000125
    68 0.02295 0.002160 0.003175 0.000625
    69 0.02095 0.001845 0.003075 0.001500
    70 0.01926 0.001545 0.002875 0.002625
    71 0.01786 0.001270 0.002550 0.003875
    72 0.01672 0.001035 0.002100 0.004625
    73 0.01579 0.000850 0.001625 0.004375
    74 0.01502 0.000710 0.001225 0.003625
    75 0.01437 0.000605 0.000900 0.003000
    76 0.01381 0.000530 0.000625 0.002375
    77 0.01331 0.000480 0.000425 0.001625
    78 0.01285 0.000445 0.000300 0.001125
    79 0.01242 0.000420 0.000200 0.001000
    80 0.01201 0.000405 0.000100 0.000875
    81 0.01161 0.000400 0.000025 0.000500
    82 0.01121 0.000400 0.000000 0.000125
    83 0.01081 0.000400 0.000000 0.000000
    84 0.01041 0.000400 0.000000 0.000000
    85 0.01001 0.000400 0.000000 0.000000
    86 0.00961 0.000400 0.000000 0.000000
    87 0.00921 0.000400 0.000000 0.000000
    88 0.00881 0.000400 0.000000 0.000000
    89 0.00841 0.000400 0.000000 0.000000
    90 0.00801 0.000400 0.000000 0.000000
    91 0.00761 0.000400 0.000000 0.000000
    92 0.00721 0.000400 0.000000 0.000000
    93 0.00681 0.000400 0.000000 0.000000
    94 0.00641 0.000400 0.000000 0.000000
    95 0.00601 0.000400 0.000000 0.000000
    96 0.00561 0.000400 0.000000 0.000000
    97 0.00521 0.000400 0.000000 0.000000
    98 0.00481 0.000400 0.000000 0.000000
    99 0.00441 0.000400 0.000000 0.000000
    100 0.00401 0.000400 0.000000 0.000000
    101 0.00361 0.000400 0.000000 0.000000
    102 0.00321 0.000400 0.000000 -0.000125
    103 0.00281 0.000400 0.000025 -0.000500
    104 0.00241 0.000395 0.000100 -0.000875
    105 0.00202 0.000380 0.000200 -0.001125
    106 0.00165 0.000355 0.000325 -0.001250
    107 0.00131 0.000315 0.000450 -0.000750
    108 0.00102 0.000265 0.000475 0.000250
    109 0.00078 0.000220 0.000400 0.000750
    110 0.00058 0.000185 0.000325 0.000500
    111 0.00041 0.000155 0.000300 0.000125
    112 0.00027 0.000125 0.000300 0.000000
    113 0.00016 0.000095 0.000300 0.000000
    114 0.00008 0.000065 0.000300 0.000250
    115 0.00003 0.000035 0.000250 0.000750
    116 0.00001 0.000015 0.000150 0.000875
    117 0.00000 0.000005 0.000075 0.000625
    118 0.00000 0.000000 0.000025 0.000375
    119 0.00000 0.000000 0.000000 0.000125
    120 0.00000 0.000000 0.000000 0.000000
    CLOSING
    -0.000180 -0.001800 0.000000
    -0.000360 -0.001800 0.000000
    -0.000540 -0.001800 0.000000
    -0.000720 -0.001800 0.000125
    -0.000900 -0.001775 0.000375
    SAME -0.001075 -0.001725 0.000375
    -0.001245 -0.001700 0.000125
    -0.001415 -0.001700 0.000000
    -0.001585 -0.001700 0.000000
    -0.001755 -0.001700 0.000000
    -0.001925 -0.001700 0.000000
    -0.002095 -0.001700 0.000000
    -0.002265 -0.001700 0.000000
    -0.002435 -0.001700 0.000000
    -0.002605 -0.001700 0.000000
    -0.002775 -0.001700 0.000000
    -0.002945 -0.001700 0.000125
    -0.003115 -0.001675 0.000375
    AS -0.003280 -0.001625 0.000375
    -0.003440 -0.001600 0.000125
    -0.003600 -0.001600 0.000000
    -0.003760 -0.001600 0.000125
    -0.003920 -0.001575 0.000375
    -0.004075 -0.001525 0.000375
    -0.004225 -0.001500 0.000125
    -0.004375 -0.001500 0.000125
    -0.004525 -0.001475 0.000375
    -0.004670 -0.001425 0.000375
    -0.004810 -0.001400 0.000125
    -0.004950 -0.001400 0.000125
    -0.005090 -0.001375 0.000375
    -0.005225 -0.001325 0.000375
    OPENING -0.005355 -0.001300 0.000250
    -0.005485 -0.001275 0.000375
    -0.005610 -0.001225 0.000375
    -0.005730 -0.001200 0.000250
    -0.005850 -0.001175 0.000500
    -0.005965 -0.001100 0.000875
    -0.006070 -0.001000 0.001000
    -0.006165 -0.000900 0.001000
    -0.006250 -0.000800 0.001000
    0.16017 -0.006325 -0.000700 0.001125
    0.15381 -0.006390 -0.000575 0.001500
    0.14739 -0.006440 -0.000400 0.001875
    0.14093 -0.006470 -0.000200 0.002000
    0.13445 -0.006480 0.000000 0.002000
    0.12797 -0.006470 0.000200 0.002000
    0.12151 -0.006440 0.000400 0.002000
    0.11509 -0.006390 0.000600 0.002125
    0.10873 -0.006320 0.000825 0.002500
    0.10245 -0.006225 0.001100 0.002875
    0.09628 -0.006100 0.001400 0.003000
    0.09025 -0.005945 0.001700 0.003000
    0.08439 -0.005760 0.002000 0.002875
    0.07873 -0.005545 0.002275 0.002375
    0.07330 -0.005305 0.002475 0.001500
    0.06812 -0.005050 0.002575 0.000625
    0.06320 -0.004790 0.002600 0.000125
    0.05854 -0.004530 0.002600 0.000000
    0.05414 -0.004270 0.002600 0.000000
    0.05000 -0.004010 0.002600 0.000000
    0.04612 -0.003750 0.002600 0.000000
    0.04250 -0.003490 0.002600 0.000000
    0.03914 -0.003230 0.002600 0.000000
    0.03604 -0.002970 0.002600 0.000000
    0.03320 -0.002710 0.002600 -0.000125
    0.03062 -0.002450 0.002575 -0.000500
    0.02830 -0.002195 0.002500 -0.001000
    0.02623 -0.001950 0.002375 -0.001500
    0.02440 -0.001720 0.002200 -0.001875
    0.02279 -0.001510 0.002000 -0.002000
    0.02138 -0.001320 0.001800 -0.002000
    0.02015 -0.001150 0.001600 -0.002125
    0.01908 -0.001000 0.001375 -0.002375
    0.01815 -0.000875 0.001125 -0.002375
    0.01733 -0.000775 0.000900 -0.002125
    0.01660 -0.000695 0.000700 -0.001875
    0.01594 -0.000635 0.000525 -0.001375
    0.01533 -0.000590 0.000425 -0.000750
    0.01476 -0.000550 0.000375 -0.000500
    0.01423 -0.000515 0.000325 -0.000375
    0.01373 -0.000485 0.000300 -0.000250
    0.01326 -0.000455 0.000275 -0.000375
    0.01282 -0.000430 0.000225 -0.000375
    0.01240 -0.000410 0.000200 -0.000250
    0.01200 -0.000390 0.000175 -0.000375
    0.01162 -0.000375 0.000125 -0.000375
    0.01125 -0.000365 0.000100 -0.000125
    0.01089 -0.000355 0.000100 -0.000125
    0.01054 -0.000345 0.000075 -0.000375
    0.01020 -0.000340 0.000025 -0.000375
    0.00986 -0.000340 0.000000 -0.000125
    0.00952 -0.000340 0.000000 0.000000
    0.00918 -0.000340 0.000000 0.000000
    0.00884 -0.000340 0.000000 0.000000
    0.00850 -0.000340 0.000000 0.000000
    0.00816 -0.000340 0.000000 0.000000
    0.00782 -0.000340 0.000000 0.000000
    0.00748 -0.000340 0.000000 0.000000
    0.00714 -0.000340 0.000000 0.000000
    0.00680 -0.000340 0.000000 0.000000
    0.00646 -0.000340 0.000000 0.000000
    0.00612 -0.000340 0.000000 0.000000
    0.00578 -0.000340 0.000000 0.000000
    0.00544 -0.000340 0.000000 0.000000
    0.00510 -0.000340 0.000000 0.000000
    0.00476 -0.000340 0.000000 0.000000
    0.00442 -0.000340 0.000000 0.000000
    0.00408 -0.000340 0.000000 0.000000
    0.00374 -0.000340 0.000000 0.000000
    0.00340 -0.000340 0.000000 0.000000
    0.00306 -0.000340 0.000000 0.000000
    0.00272 -0.000340 0.000000 0.000000
    0.00238 -0.000340 0.000000 0.000125
    0.00204 -0.000340 0.000025 0.000625
    0.00170 -0.000335 0.000125 0.001125
    0.00137 -0.000315 0.000250 0.001125
    0.00107 -0.000285 0.000350 0.001000
    0.00080 -0.000245 0.000450 0.000625
    0.00058 -0.000195 0.000475 -0.000250
    0.00041 -0.000150 0.000400 -0.000750
    0.00028 -0.000115 0.000325 -0.000625
    0.00018 -0.000085 0.000275 -0.000500
    0.00011 -0.000060 0.000225 -0.000500
    0.00006 -0.000040 0.000175 -0.000500
    0.00003 -0.000025 0.000125 -0.000375
    0.00001 -0.000015 0.000100 -0.000250
    0.00000 -0.000005 0.000075 -0.000375
    0.00000 0.000000 0.000025 -0.000375
    0.00000 0.000000 0.000000 -0.000125
    BASE CIRCLE
    Radius = .63857/.64057
    NOTES:
    1. Inlet and exhaust lobes are identical and asymmetrical
    2. 3863143 has a groove in the rear journal, 3904362 does not; camshafts are otherwise identical
    3. Lobe also used on LT-1 cam inlet side on a base circle radius of .59874/.60074,
    point of maximum lift, 110 deg. ATDC
    • Clem Z.
      • January 1, 2006
      • 9427
      duke he ask what time it was
      not how to build a clock.
      • Keith McVay
        Re: 427 Cam Shaft
        Thanks for all the information, but I still didn't get the lift and duration that I was looking for. I can't work cross-word puzzles If I were going to buy an aftermarket cam the the 427(425hp) what is the closest one that I could get to the GM specs?
          • 15610
          Re: 427 Cam Shaft
          The answers to your questions are in the data I provided. The cam is available from F-M Speed Pro.
          • Clem Z.
            • January 1, 2006
            • 9427
            Re: 427 Cam Shaft
            i would go with GM 12364057 cam and kit. it is the 3863143 camshaft made by crane for GM
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 427 Cam Shaft
              Keith,
              Clem is on the money, as usual. His suggestion to go with the GM/Crane cam would be my first choice. They make a dead on copy of the original 3863143 425 HP GM cam and their quality has always been excellent.
              As far as lift/duration etc numbers, I can post these for you but those numbers really are meaningless to 98% of the world. The numbers are in Dukes post above if you study the page but you still won't know any more than you did before you read it. The 143 cam is an excellent choice for all solid lifter street applications.
              Michael
              • William V.
                • December 1, 1988
                • 399
                Re: 427 Cam Shaft
                Please refrish my memory I must be getting old. Did the 66 427 need the oil groove on the back camshaft journal like the 65 396?
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Re: 427 Cam Shaft
                  You are correct Bill. The original desigh for both 65 and 66 BB engines had the grooved cam journal instead of the 67 and later grooved bearing.
                  Most engine rebuilders today install the grooved bearing for all BB engines including the 65-66 breed, even if it does have a grooved cam journal. It's ok to have both the cam journal and the bearing grooved but not ok to have no groove at all.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    Re: 427 Cam Shaft
                    if the rear cam bearing has 3 holes you need a grooved rear cam bearing journal,3/16" wide and 3/16" deep. the groove is to feed the lifter gallery. after doing this in the small block in the early days why would they repeat the same mistake with the big block???
                      • 15610
                      Re: 427 Cam Shaft
                      "The numbers are in Duke's post above if you study the page but you still won't know any more than you did before you read it."
                      Sure you will. You'll know the complete dynamic characteristics of the L-72 cam.
