A couple of questions regarding the installation of the interior door handle rod:
1. There is a bracket which fits over the interior door handle shaft. When the door handle button is pushed in, a swivel that is part of that bracket pushes foward and lifts the rod which is attached to it. What holds this bracket onto the door shaft? It is not displayed in the assembly manual. The bracket hole fits over the door handle shaft (attached to the push button), but it wants to fall off. 2. The assembly manual shows that a washer and spring are fitted on the rod at one end and a cotter pin on the other end. What keeps the washer and spring from sliding down the rod? I know I must be missing something but not sure what it is. Thanks. Richard
