1981 headlight support brackets
  • Buz
    #1
    both left and right sides have broken support brackets (frames) and both assemblies have drop below the nose about 3/8 inch. I would like to know if the can pass out the bottom of the car or do I have to take the front bumper assembly off.Also has anyone tried to repair the frames?? I see their hard to find and expensive.I have the facilites to weld most metals including aluminum, die cast & pot metal but I not sure what their made of.
  • David D.
    • 330
    Re: 1981 headlight support brackets
    Buz,
    Don't know if this is going to help you anu, but here goes.
    I recently purchased a 73-74 Corvette upper nose section with the
    complete headlight assemblies, supports, etc., still intact.
    I believe the mount brackets are the same as yours. I just
    looked at the brackets, it has a couple of the ends where they bolt
    to the header support broken also. But, I noticed one othe other one
    has been repaired before by I believe TIG welding. It looks like the
    welding wire used is aluminum, so I would say the are most likely cast
    aluminum. Hope this helps. Maybe someone else can verify this.
    Dave NCRS #16980
