C2 drivetrain noise - NCRS Discussion Boards
C2 drivetrain noise
  • Noel K.
    • November 1, 2004
    • 84
    C2 drivetrain noise
    At some point i hope to be able to post a more positive message on this forum. Some may recall i recently described having to pull the small block out of my "frame off" restored '65 convertible in order to repair the engine. A floating wrist pin (without keeper) had been installed in one of the cylinders. I found a great local machine shop and we went completely through the engine.
    While trying to put a few miles on the engine I was sitting at a stop light this past weekend when a noise began coming from the transmission area with a "vibration" felt through the shifter. I've concluded the throw out bearing is failing and will now need to be replaced. Would have been a simple fix when the engine was out but now I will have to pull the transmision.
    Asking for suggestions to consider while the transmission is out. I will, of course, check the clutch and pressure plate (the flywheel was resurfaced when the engine was out ) but was wondering if i should replace any other items at this time i.e. u joints, etc. The transmission itself seems to be fine - there were no previous shifting problems.
    Lastly, regarding short or long throw - which is most correct for judging standards ?
    The worst part is that I will now have to tell my wife there is another repair issue to be dealt with ! ! !
    Thanks all,
    Noel Kendall
    Re: C2 drivetrain noise
    Noel -
    The "long-throw" shifter setting is the only one acceptable for full judging credit, as that's the way the car was built.
    • Alan Drake
      Make sure pilot bushing in crank was replaced. But yes I've seen some very good shops forget this minor item.
      • Chuck R.
        • April 30, 1999
        • 1434
        Hi Noel,
        I'd also venture a check for loose flywheel and pressure plate bolts.
        At least you can check the pressure plate bolts first before you tear into the tranny.
        My two pennies worth.
        Chuck
        • Wayne K.
          • December 1, 1999
          • 1030
          Noel, rule of thumb .....
          if you spend as much on your wife as you do on the car things will usually be OK.
