1965 Parking Brake Handle - NCRS Discussion Boards
  • Dave Marshall
    When turning the parking brake handle to the right to release the brake, should
    the handle only turn 90 degrees and stop? Mine turns a full 360 degrees. It seem it should have a stop but I don't recall there being anything from a few years ago when I dismantled it. Thanks for your help.
    Dave Marshall
  • Don H.
    • December 1, 1981
    • 1482
    Re: 1965 Parking Brake Handle
    Mine turns 360 - could not say for sure this is correct. Don H.
    • Eugene B.
      • May 31, 1988
      • 710
      Dave and Don,
      Definately not correct. The handle will rotate approximately 90 degrees clockwise when released. I believe that you are missing a pin assembly with an approx. 1/2 by 1/2 inch head. This pin assembly is pressed into a hole in the rod. The square head acts as an actuator for the parking brake light switch. Hope this helps.
      Good luck,
      Gene
      • Mark S. Lovejoy
        The handle should not turn 360 degrees, just 90.
        There should be a pin at the lower part of the shaft that stops it from spinning 360 and also turns off the E-Brake light on the dash.
        If your handle spins, the light should be on all the time, assuming all is well with the electrics.
        Mark
        27152
        • Dave Marshall
          I appreciate your help. I think I see the pin you are talking about in LI Corvette Supply's catalog. That makes more sense to me. Thanks a bunch to all.
          Dave Marshall
          • Eugene B.
            • May 31, 1988
            • 710
            Dave,
            You are on the right track. In the LIC catalog #23, you are looking for item number 07B (Handle stop pin). Glad we've helped you a little.
            Best regards,
            Gene
            • Dave Marshall
              Gene and All,
              I've been helped numerous times from many members. There's a lot of good, hard-to-find information amongst the group. I really need a lot of help and appreciate it very much. Thanks again.
              Dave Marshall
