C3 build date - NCRS Discussion Boards
C3 build date
  • Steven E.
    • June 30, 2005
    • 6
    C3 build date
    I have a 73 (L48) coupe and would like to fiqure out the build date ,
    The trim tag number is C28 which translates into Oct. 28,1972
    The "blue vehicle certification label" number is 02/73. I have a few questions, Did the body sit for 4 months before it was actually mated to the frame.?
    I understand that it is normal for a day or even a few days but is there something not right with these dates.? And is there a way to find out the exact day this car was built.?
    The dash VIN , and the blue label on the door have matching numbers..
    The production number is 16,295..
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 build date
    Steve
    Your 73 was built Feb. 28th which is correct fot vin 16295. Their is very little difference between a C and a G only the circle comes up a little higher. I am sure your 73 is a G on the trim tag by the other information you provided. Lyle
    Lyle
      • 15573
      Re: C3 build date
      I would bet the trim tag is G28. That would make it February 28. It is exceedingly difficult to tell the difference between a C and a G on the trim tag.
      • Steven E.
        • June 30, 2005
        • 6
        Re: C3 build date
        Thank you both for the helpful information, indeed in checking again it is a G. It is extremely difficult to tell the difference between the C and the G. Thanks again!
