Harrison Radiator sticker - NCRS Discussion Boards
  • Gary #41345
    Is the position of the Harrison Radiator sticker to the left of the center support when looking at the radiator from the air cleaner? And are there any dimensional requirements that must be maintained according to it's position?
    Re: Harrison Radiator sticker
    Gary -
    As viewed from the rear, the outboard edge of the sticker is about 1/4" inboard of the fore-aft "line" through the passenger side of the top plate.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's another factory sticker position ....
      just removed original off SB rad 66M. John H's dimension is 3/4" in my case, and LH of sticker edge starts 5/8" to the right of the raised pad for the center rad cushion bracket. The sticker itself is 5-3/8" lg x 2.0" high. A re-pop I have is about 1/8" longer.
      The fonts and wording position vary considerably on the reproductions, (and [who knows ?] maybe did so also on the orignals, depending on the year.
      • Gary #41345
        Re: Here's another factory sticker position ....
        Thank You John and Wayne, 1/8 of a difference will not make alot of confusion for me as I'm not looking for perfection just "close" works for me ....again thanks for the info.....I would assume it was centered from top edge to bottom edge of the top plate?
        • Wayne M.
          • March 1, 1980
          • 6414
          I think that was Harrison's intention
          Centered top-to-bottom. In 66M's case, there was 1.00 centimeters top to rad edge, and bottom, 1.31 cm. The sticker was slightly off-kilter with 1.01 cm top at right end, and 1.30cm bottom.
