rear window storage tray mounting dennis moore i have coupe which had the rear window tray but not installed the carpet was not correct so i installed new carpet but when i went to install the window tray found the mounting plate holes behind the carpet should the carpet be cut out for this mount or be mounted over the carpet on the rear bulkhead or mount behind the carpet the assembly manual shows the bracket attached right up against the mounting plate also the engine is in fairly original condition with the exception of the carb which had been replaced the coil on this appears to be the original one but it a
1968 Rear window storage tray mounting
