68 coupe 4-spd 435hp - NCRS Discussion Boards
  • Houston U.
    • June 30, 2000
    • 75
    What GM part number would be on the bellhousing of a 435hp engine? The flywheel is #3789733 (D 15)?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68 coupe 4-spd 435hp
    Don does this mean the scoundrel thieves did not steal the bell housing?
    • Mark #28455
      all bb used #621 except L88 *NM*
      • Houston U.
        • June 30, 2000
        • 75
        Jim, the engine and tranny were dismantled and stored inside a garage awaiting restoration. They left heads (alum.),intake manifold from BB '70, bellhousing (621), flywheel. I found in a box one carb. (it is the middle holly for a 3X2 set up '68) All numbers so far are coming back as 435hp except gas tank. But I haven't determined if it is original (it looks like it though).
        • Mark #28455
          what about fuel lines on the frame?
          Mark
          • Mark #28455
            Does it have the transistor ignition box on the driver's side (not sure where the 68 is mounted but in 69 on the front of the inner fender in front of the radiator) or the holes for it? How about the original distributor?
            Mark
            • Mark #28455
              check the underside of the differential, what code is listed. Certain ratios were only available with certain engines - ie: FB is for 427, 4.10:1 ratio and was only available with solid lifter engines.
              Mark
              • Dick W.
                • 10483
                TI box on 68 mounted same as 69. Box does not have "pigtail" wiring harness
                Dick Whittington
                • Houston U.
                  • June 30, 2000
                  • 75
                  Mark, the fuel lines are 3/8" with no return line (that I can find).
                  • Mark #28455
                    so probably the tank is a replacement and the lines are original - as they are something of a bear to change. If so, then it's 400 HP or more. Given your recent post about the distributor #296 I suspect you are correct that it is either an L71 or an L89. They did make about 700 L89's in 1968 so it is certainly a possibility. There is no way to tell an L71 from an L89 car, the only difference is the heads and the block stamping.
                    Good luck,
                    Mark
