67 327 Ignition Shielding Front Clip - NCRS Discussion Boards
  • Tim S.
    • April 30, 2002
    • 8
    I'm Trying To Install New Front Clip On Top Ignition Shield. Can't Figure Out How Or What To Use To Brad Rivets, Not Enough Room Inside Top Shield . Need Help
  • Rob A.
    • December 1, 1991
    • 2126
    Re: 67 327 Ignition Shielding Front Clip
    Tim,
    I happened to have had a rivet gun set, which had several different shaped, heavy bucking bars. I placed one on the inside of shield against the back of the rivet, while I used the curved rivet set on the head with a hammer. Find something fairly heavy, like the head of a hammer, sideways to place against the back of the rivet and do the same. (Don't forget the washer on the inside of the shield) If you reuse the original rivets and washers it's easier. They won't require so much force to secure the clip.
