Acc. rod-- '68/'69 3934092 Questions - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 543
    I think this is the correct part number for a '68/'69 "Z" bar accelerator rod(the piece that is attached to the acc. pedal with a pin, then goes through the bracket on the firewall, then has the "twisted" lever attached that connects to the cable? Is this rod available? What should I expect to pay for a new or used one (can these be found)? Mine broke at the flat end where the cable lever attaches. Thanks to all, George
  • Mark #28455
    Paragon has it *NM*
