I feel like I need to go back to basic 101 again but I'll ask the question anyway. Transmision was starting to grind going from 1st to 2nd....then over a period of time it started from 2nd to 3rd then to 4th (I bypassed 2nd when this started to happen). So I thought the syncros were going so pulled the tranmission out, go a rebuild kit from my wife for Christmas, and just pulled the side cover off this weekend and did a visual inspection of the inside. Everything looks great...no shavings...no missing or ground teeth on syncros, and the gears, sliders, etc., look great also.
Now the question, was the solution all along just to adjust the clutch rod? Or even though the tranmission gears look good the syncros could still be bad?
Appreciate any thoughts....feeling stupid in VA.
...Larry...
...Larry...
