I'm cleaning up a cowl-back body which is rather oil-soaked and torn in areas. I've been told to *never* use solvent in an area you will be applying adhesive, as the adhesive will not stick (This was stated in reference to front clip glueing strips). How can I degrease and clean up these oil-soaked torn areas (floor, firewall) which will need resin, glue, etc. to be able to stick to them subsequently? Are epoxies as sensitive as polyester-based materials when it comes to bonding to an area that once had solvent on it?
Thank you, Patricia
Thank you, Patricia
