Continuing saga. I am attempting to start the engine with the body off. I am using the main harness and ignition harness. I labeled all the connections during disassembly, and everything (I think)is connected as the same as if the body were on (starter, alternator, voltage regulator, ballast resistor, etc). But I when I turn the ignition switch to start, I get nothing from the starter. I am thinking that I've missed a ground wire some where. I have a wire (black with white stripe) that I had labeled "cluster ground", and have connected it to ground. What else am I missing?
Steve
Steve
