Are there some early 68 owners out there that have had their original gas tanks out. Did any of you find a wire attached to a post located between the filler neck and the return line on the top right side of the tank.
I have what I think is an early 68 tank out of a 390hp car. It has a round disk attached between the filler neck and the return line. The disk is about 2 inches in diameter. I removed it and it is part of a float machanism that seems to activate when the gas tank is about 3/4 empty. It all looks very factory. Tank looks original for 68 (not a replacement). It has the gage float on the bottom side as usual. Any ideas appreciated.
