In cleaning up my newly acquired '72 cowl-back body, I came across some little (1" wide, 1/2" tall) flat "tabs", about 6 or 8 of them, screwed across the top of the windshield frame. Do these have something to do with supporting the glass?
Anyway, most of them unscrewed but a few which were stripped and I had to drill them out. I'm down to one remaining, stubborn screw which refuses to be drilled out. I am using cobalt bits (the hardest my local hardware store carries) and they won't touch it. It's dulled 3 of them now. I know nothing is wrong with the bits because they went through the other screws like butter (even after being dulled). It sits and spins on the screw and won't even throw any slivers. I finally used a cut-off wheel on my Dremel and was able to take the head off and remove the "tab", but the screw's shank is still stuck in there. Is there any way to remove such a super-hardened screw? Do they make drill bits harder than cobalt, and where can I get one?
Thanks! Patricia
Thanks! Patricia
