If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Hi
I have a 1966 427 hood and the problem is the outer skin is not connected to the under side fiberglass frame work (It flexes). There is an adhesive that is used to connect the two together. Does anybody know the correct adhesive and why it would be missing from this hood?
This has been discussed here probably a hundred times. You might want to look in the archives. The gist is that the hood was only bonded around the perimeter and not actually bonded on the inside support. A non hardening puddy like material is used there. It is applied in the area of the little flat tabs.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
