Oiless engine demo
Yeah, I remember seeing a similar demo at the Pomona swap meet years ago. It was an old Chrysler slant six with no oil pan, just barely turning over at maybe 400 RPM. When I was a kid I remember seeing a demo at the Seattle Auto Show. This guy had a rotating cup with three big ball bearings. He poured in some motor oil then brought down this cone with a lever to load up the bearings. Within a few seconds the cup started smoking and the bearings seized together. Then he ran the test with a miracle additive, and, of course, they just kept turning now matter how long and hard he pulled on the lever. Years later I asked one of my professors who taught a bearing design and lubrication class about this demo. He knew the drill. These formulations have a heavy dose of EP (extreme pressure) additives that will provide good low speed "boundary lubrication", but in an automotive engine, most lubrication is between high relative velocity surfaces and a hydrodymanic film is developed which keeps the surfaces apart. It's like hydroplaning on the freeway in the rain with bald tires. Most guys think of oil pressure in terms of feed pressure from the gallery, but the pressure developed inside the bearing is several THOUSAND pounds per square inch. One exception is the rings, which come to a complete stop twice per revolution, and they are loaded by gas pressure every other trip to the top. This is why bores taper, but modern oils have sufficient EP additives to keep taper wear reasonable, and nobody has ever proved that more EP additives will reduce taper wear during normal use. The old slant six is probably still idling, because at a 400 RPM idle with no load, the EP additives provide enough boundary lubrication to keep the bearings from seizing.
Regarding the Porsches, they have a 12 quart sump and an oil change interval of 15,000 miles or one year.
