1967 L88 - NCRS Discussion Boards
1967 L88
  • William O.
    • April 30, 2001
    • 355
    1967 L88
    I am closing in on a location of a "so called" long lost 1967 L88.
    Question:
    Have all of the 1967 L88's been accounted for?
    Does an original list of dealers or buyers of these L88 exist?
    Would a list of "shipped to" exist?
    Any feed back would be helpful.
  • mike mccagh
    Re: 1967 L88
    is it a black coupe? MIKE
    • William O.
      • April 30, 2001
      • 355
      Re: 1967 L88
      White 1967 L88 convertible was built on June 22
      Thanks.
      • Michael H.
        • January 29, 2008
        • 7477
        Re: 1967 L88
        William,
        No such list of original selling dealers or purchasers of L88's exists, unfortunately. That would be too easy. No GM records have ever been found for any C2 cars. The best you can do is hope that by chance the car has a GENUINE tank sticker/warranty book or some other real paperwork, and even that isn't conclusive these days.
        As far as the number of cars found, I believe the numbers go something like this. Of the original 20 produced, there are 12 or 13 that are considered absolute genuine. Another 4 or 5 that are considered "probable/possible", and about 25 more that are questionable. (these numbers may have changed a bit over the years)
        The problem with trying to document an L88 is, they're not difficult to "build" if a few key ingredients are located. The engines and most of it's bolt on components are quite plentiful so you can't possibly document the car that way. Most of the L88 body items are bolt on so anything can be created. Hope this helps.
        Michael
          • 15610
          Re: 1967 L88
          My answers to all your questions are: Not that I'm aware of!
          Unless the car has some bonafide factory or dealer paperwork it's impossible to unequivocally "prove" that it is one of the 20 actually produced by St. Louis.
          It seems that a lot of "lost L-88s" have shown up lately. One of the running jokes about '67 L-88s going back nearly 20 years is that "of the 20 produced all 50 (or fill in your own number) are accounted for."
          If there is no paper work you are left with looking at the numbers, such as the engine stamp pad, a proper date, code, and VIN derivative on the M-22, and date/code on the axle, and all the other visual signs - proper carb/air cleaner, road draft tube crankcase ventilation,no radiator fan shroud, C-48, J-56, and F-41.
          Also, it should be a fairly "late" sequence number. I don't think the first '67 L-88 was produced until April, but it may have been March.
          • William O.
            • April 30, 2001
            • 355
            Re: 1967 L88
            Thank you for you response and data.
            The one I am hunting for and hopefully soon to be found, has been in the same location and "Damaged" since 1969. I will keep everyone posted.
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 1967 L88
              I think I may know which one you are refering to. Hope ya get it. Good luck.
              • William O.
                • April 30, 2001
                • 355
                Re: 1967 L88
                Duke:
                The build date is 6/22/67
                When I find it I hope to see ... if there is a car to be seen, the tank sticker or documentation.
                Regards.
                • mike cobine
                  Re: 1967 L88
                  The unfortunate part on the engine is that while at the Bloomington Gold Special Collection in '88, several of the '67 L88 owners there told me they did not have their original engine and that it had been long gone.
                  So that means two possibilities exist:
                  - these cars may not have been real
                  - the potential for a fake car using a real engine (one of the lost ones) existed.
                  We get into the vintage race car syndrome where as long as you have an original part, you can build an original car. In vintage racing, there are many cases of one original car generating several "original" cars from the discarded parts over the years.
                  Just be very careful what you pay for.
                  • Curtis L.
                    • August 31, 2003
                    • 120
                    Re: 1967 L88
                    Duke made a good point. Every time I look at chevy trader or mecum or many of the other auctions there is another L88 that shows up. If you looked in every magazine and every up coming auction in this counrty you can probly count 50 L88's not counting the many L88's that proteam and many other dealers have stashed away.Oh yea don't forget about Barret-jackson, they must have 5 or 6 they just discovered and ready for the hollywood auction......
                    • Warren F.
                      • December 1, 1987
                      • 1516
                      Re: 1967 L88
                      William:
                      There is a knowledgeable poster on the Corvette Forum, that says that eighteen of the twenty have been accounted for.
                      • Steven C.
                        • April 30, 2002
                        • 199
                        Re: 1967 L88
                        William, you might try Kevin Mackay. He may be able to help.
                        • James G.
                          • May 31, 1976
                          • 1556
                          Re: 1967 L88
                          Drew Papsen has the vin numbers of the cars discovered to date. I have the list as well. Of the 20, I have one missing vin in the time period described.
                          I will share my knowledge carefully.
                          • Drew P.
                            • June 30, 1977
                            • 180
                            Re: 1967 L88
                            Hello Jim,
                            There are 10 Corvettes that have factory documentation. The documentaion is a window sticker or tank sheet.
                            Drew Papsun
