Corvette master cylinder - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    I have a 5455509 master cylinder with a D7 stamped on it. I think it came off a 1970 Corvette but I do not know anything else about it. Anyone know?
    Scott
  • don 42616
    Re: Corvette master cylinder
    Scott. I just purchased one on bayfor my 67 P/B. They are hard to find. At least I had difficulty. It was rebuilt & perfect condition so I paid his buy it now. I believe it is manuel or PB.
    • Kurt B.
      • July 31, 1996
      • 971
      Don,
      Are you saying the same master cylinder can be used for both Manual and Power Brakes? I always thought they were different, at least in bore size and perhaps other differences as well.
      Kurt # 26406
        Kurt -
        For '67 (only), the exact same master cylinder was used for both manual and J50 power brakes - the 5455509, stamped "DC" on the machined surface at the front, and a "deep-hole" rear piston.
        • don 42616
          Kurt, I just bought a 509 with a DC stamp in front on e bay. Installed it in a 67 power brake. From the help I recieved on tech. line it was correct for all 67s EXCEPT J56 Heavy duty.
          After 67 it was used only on NON P/B. Hope I have it correct. Works good on my 67 P/B tho. Don
          • Kurt B.
            • July 31, 1996
            • 971
            Thanks John, I learned something today.
            That's why I love this forum.
            Kurt
              Yup, that's why the '67 power brake booster used a LONG front pushrod; all other year power brake cars used the SHORT front pushrod, as they had the shallow hole in the rear piston. Manual brake master cylinders always have the deep-hole rear piston so the pedal pushrod won't fall out.
