462 heads vs 291 heads - NCRS Discussion Boards
  • James
    Is there any difference beteween these two casting numbers other than the casting number itself?
  • Mark #28455
    temp sender boss? *NM*
      Re: 462 heads vs 291 heads
      They're essentially the same except the 291 has the temp sender boss (undrilled for '67, drilled/tapped for the temp sender in '68).
      • James Kennedy
        Thanks!
