67 300 HP Powerglide throttle return spring - NCRS Discussion Boards
  • Joe R.
    • March 1, 2002
    • 1356
    The throttle return spring shown in the photo below does not conform to what is shown in the AIM, but I have a few questions that I hope someone can answer for me.
    The 1967 AIM shows two identical springs, both coming from the rear of the carb. One spring ties to the kickdown linkage as shown in the photo. The second spring connects between the bottom of the carb throttle lever and the tab on the crankcase vent tube support.
    Using two identical springs obtained from Dr. rebuild I can duplicate the arrangement shown in the AIM, but the throttle return spring is a bit loose, and the point where it ties to the carb linkage results in an undesirable over-center position at wide open throttle. It just doesn't work very well.
    The forward-mounted black spring in the photo is what the car had when I got it, and it works very well. The spring is attached to a mounting plate that would otherwise be unused if I followed the AIM. I also note that the diagram in the AIM shows an AFB carb and is clearly a carryover from an earlier year.
    So, it the arrangement in the photo just plain wrong, and should I try to duplicate what the AIM shows, despite the functional shortcomings? Or is it possible that there was a running change some time during 1967? My car is an April 1967 car.
  • Geoff C.
    • May 31, 1979
    • 1613
      Re: 67 300 HP Powerglide throttle return spring
      One of the photos in Noland's book and two in the Dobbins book show '67 M35 300hp cars with what appear to be two identical light-colored small-diameter springs, with the front one anchored at the bracket at the front corner of the intake.
      • Joe R.
        • March 1, 2002
        • 1356
        Hi John:
        Thanks for the suggestion to look at those old photos. It looks to me that the photos show quite a range of implementations.
        The photo on page 391 of Noland's book (second edition, in case the page numbers changed) shows both springs coming from the rear, as shown in the AIM. The photo on page 392 shows a large diameter throttle spring coming from the front.
        In the Dobbins book, the photo on page 244 shows a small diameter spring coming from the front, although it is somewhat shorter than the kickdown spring. Is there another Dobbins photo that I missed?
        I checked my 1972 parts book, and at that time Chevrolet was still calling out two identical springs for the 67 PG, although the part number had changed from what is shown in the AIM.
        I'm starting to suspect that perhaps the two identical rear-mounted springs were in fact installed at the factory per the AIM, but it was a poorly engineered solution that may have generated customer complaints due to inadequate throttle return pressure. A simple dealer fix would have been to install the forward spring used on non-PG cars.
        I note that the 4th edition of the JG calls for "two lime green return springs running to the vent tube," so I think I will install the throttle return spring that way only when the car is being judged (by the way, the kickdown spring does NOT connect to the vent tube, it connects to the ignition wire harness support). When I'm driving my car, I will use the forward mounted spring as shown in the photo I posted.
        Lastly, is it true that the forward spring mount that is bolted to the front two intake bolts would still be installed, even if it wasn't used per the AIM?
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Geoffrey:
          Thanks for your comments. I guess that the small block PG was a sufficiently rare option that we may never be certain what the configuration looked like when the cars were delivered. As noted in my response to John Hinckley, there were three different implementations shown in the three photos I could find in the Noland Adams and M. F. Dobbins books.
          Do you know for certain that the 5.7" free length of the spring you sell matches the 3904245 spring called out in the AIM? If so, I think that GM had a poorly designed system. While the installed length of the kickdown spring is about 7 inches, the installed throttle return spring length is only 6 inches. Stretching a 5.7 inch spring to 6 inches provides almost no return pressure on the throttle at low throttle positions. In fact, I think the spring could almost fall off from engine vibration.
          It seems odd to me that GM would specify the same spring for both locations when the working range is so different.
          • Geoff C.
            • May 31, 1979
            • 1613
            I'll look for the blueprint *NM*
              Joe -
              Looking at the page 244 photo again, more closely, it appears that the front spring is smaller in diameter than the rear spring; based on all the conflicting photos, it appears most folks "fixed" the spring setup.
              • Geoff C.
                • May 31, 1979
                • 1613
