Is this a correct rear member - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    My newly aquired 72 has a rear member that reads 3871375 I was told by a friend that he thinks it should be 3899143. Do I have the wrong rear or did I find the wrong number. This was located on the rear of the unit near suport at top.
    cal
  • Warren F.
    • December 1, 1987
    • 1516
    Re: Is this a correct rear member
    Cal:
    According to Colvins book Corvette by the Numbers. Your Axle Center section Casting number should be 3899143 for 1967 thru 1975 years.
    • Calvin C.
      • May 31, 2002
      • 240
      So what is 3871375, Did I look in the wrong location?
      cal
      • Warren F.
        • December 1, 1987
        • 1516
        I cannot find that number in my 1953 thru 1972 parts book. However 3871374 is Axle Housing Cover with Filler Plug, applicable for 63 thru '74 Corvette.
        • Calvin C.
          • May 31, 2002
          • 240
          I must be looking at the axel housing, but is it corect?
          cal
          • Warren F.
            • December 1, 1987
            • 1516
            Cal:
            Sometimes the part number and casting number can be close, such as this. I just don't know, you need Joe Lucias expertise here.
              Two different parts here - the rear COVER (that the spring attaches to) is casting #3871375 (at top rear of the cover), and the differential housing is casting #3899143 (driver's side, behind strut rod bracket).
              • Warren F.
                • December 1, 1987
                • 1516
                Thanks, John *NM*
