If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I'm looking for the "correct" paint to use on my gauge cluster. The "bible" says semi-gloss, but that seems awful shiny. The semi flat seems too flat. Maybe I'm just using the wrong type of paint, not the wrong gloss. Is there an agreed upon standard that I should be using? Thanks for any help.
and navigate to www.autocolorlibrary.com. Instead of telling the menu that you've got a '66 Chevy, LIE and tell it you own a '65. You're doing this because their library contains more/less information from the PPG color chip set from year to year and there's no 'page two' info for '66 but it's there for '65!
You'll see a list of on page two of what paint, by blend code was used on what interior surfaces and you'll note the list is DIFFERENT for Chevy passenger cars vs. Corvette. Not only will you get the blend code for what was used on the instrument cluster, it'll tell you specific gloss factor to whip up.
Terms like flat, semi-flat, semi-gloss are USELESS as they're simply generic terms. Real painters mix & shoot based a 0-100 degree gloss scale and if memory serves, the PPG target is for a 3-degree gloss factor on the surface you're questioning....
------I have probably detailed and painted 50 or more clusters and as many glove box doors and black consoles over the years and dont think I have ever lost a point with Krylon Semi-gloss. Im having some brain fade as to weather they call it semi-flat or semi-gloss, but I believe they only have one semi black. I do shoot it a bit dry (can a bit distant from the part) but thats the only different thing I can think of. Hope this helps.........Bill S
I prefer the SEM Trim Paint in the "original" formula. It's been a dead-on match for the ones I've done, and I find it more durable than Krylon's semi-flat.
Patrick
-----I would venture to say that you are correct about the durability issue. It hasnt been much of an issue on the interior pieces mentioned, but under the hood and elsewhere I do find Krylons durability lacking.........Bill S
Bill,
Painted the console on my 67 with Krylon and have not been impressed wih the durability. I am going to repaint it this winter and will give SEM Trim paint a try as Patrick suggested.
Rick
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
