All:
My 1965 327/365 engine does not smoke, the R44 plugs are clean, with light tan insulators. The engine has 700 miles on a rebuild, and uses Shell Rotella 15W-40 oil. The reproduction, "correct" tapered end dipstick tube is fully seated in the block, but reads 3/8" below the full mark with 6 quarts, with the old type filter can. I made the mistake of adding an additional 1/2 quart to bring the level to "full", but I will shorten the tube by 3/8" to correct the low reading dipstick.
All of this background information leads to my point..........the engine uses about 1 quart every 500 miles (with the 1/2 quart overfill, which is probably not enough to affect engine operation). About half of this is highway mileage. Normally, travelling at 70-75 MPH, with 3.70:1 gear means sustained 3500-3800RPM (approximately) cruising.
By way of comparison, my 1985 uses 1 quart, about every 3000 miles, but cruises at about half the engine speed of the 1965. That translates to 1 quart every 1000 miles for the '65 if it had the 1985 gearing and overdrive.
So, how does this look? I would like to hear about some of your oil consumption amounts, for comparison.
Thanks in advance.
Joe
Thanks in advance.
Joe
