C2 oil pressure line drawing - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    I am looking for a drawing of the oil pressure line on my '65. I'm sure that the original no longer has the proper shape. I'm also not sure of the routing around the linkages and tach cable.
    Does anyone have a drawing that they can FAX?
    Thanks in advance,
    Gene
    Re: C2 oil pressure line drawing
    Gene -
    '65 Assembly Manual, Section 12, Sheet C2.
    • Eugene B.
      • May 31, 1988
      • 710
      John,
      Thank you for your reply to my oil line question. The AIM shows the general shape of the oil line.
      I was hoping for a drawing of the line (P/N 3718812) that specifies the dimensions and angles of bends. I wonder if the copper plated steel line from Paragon comes pre-bent, or coiled for shipping purposes?
      Thanks again for your reply.
      Best regards,
      Gene
        Gene -
        I'm sure the original drawing showed the configuration, but I don't have one. The Paragon line comes in a "U" shape, with the special fittings for both ends.
        • Eugene B.
          • May 31, 1988
          • 710
          Re: Thanks, John *NM*
