1966 tach and oil pressure gages - NCRS Discussion Boards
  • steve artus
    what were the different tach and oil pressures gages markings for the 327 and 427 engines?
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 1966 tach and oil pressure gages
    Steve,
    In 66, each of the four available engines had it's own unique instrument cluster package. The base 300 HP 327 used a 60 Lb oil ga with a low RPM tach. The 350 HP 327 used a 60 Lb oil ga with a mid range tach.
    The 390 HP 427 used an 80 Lb oil ga with a low RPM tack, and the 425 HP 427 used an 80 Lb oil ga with a high redline tach.
    Michael
