63 Wiper Motor Rebuilt But I Can�t Squirt
The picture is gone but I found defective check valves in a brand new replacement white plastic pump head. You can test it by blowing fluid through from the reservoir tube end. It should blow fluid through the nozzles.
If you try to suck from the reservoir ends, the check valves should close tight.
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
