Hello all.
Working on My "72 BB. Now the engine is not original but I managed to get a rebuilt '73 correct casting number BB and a fair price so that is what I am working on. The oil pan that came on the engine was wrong so I am changing it to a correct oil pan from GM. I bought one the other day with the baffle. Before I proceed let me appologize for the my lack of knowledge on the terms. I am not much of an engine guy .... yet.
First, the pan does not sit correctly because the round "oil pick up" seems to be hitting the back of the "cage" that is built into the bottom of the pan. It is basicaly causing the pan to not match up with the mounting holes on the block by about a quarter of and inch, maybe just over a quarter inch. Is this easily fixed my buying a correct pick up? The pump looks to be in great shape but I can not tell if it is new or original. Do the pumps come in different sizes so this could be off too?
Secondly, the baffle that came with the pan needs to be mounted. I bought the baffle studs from Paragon and I believe I found where they install. I need to replace the bolts that are currently in place. What torque is needed to have these proporly intalled?
Third, this is a 454 and I installed a new oil presure line and oil pressure line bracket. The bracket mounts to the block....is it painted or left alone? Also, there are a number of oil pressure addapter fittings. One mounts to the block then a small one to make the transission to a third that accepts the metal oil pressure line. This third seems to come to a point at the end that fits into the second addapter but I can not figure out how it makes an air tight fit with the metal line. I have tightend it all the way yet but the line easily pulls in and out of the fitting. Just wanted to know if I am missing something or it realy needs to be tighted all the way. this looks like a plumping issue...which i have done some plumping before, and I just can not figure out how these three fitting tighten around the metal oil pressure line to make it air tight.
I think I have one more question but I will save it for later, unless I can figure it out.
Sorry for the long post.
Thank you much.
Brandon
Thank you much.
Brandon
