Can anyone out there answer a rather simple question I have regarding my tranny?
I have located a small fluid leak at the point where the throttle value control lever & shaft enters the transmission. I note, via the shop manual, that there is an o-ring at this point which is probably the source of the leak. There is not a lot of room to work with therefore my question is - "Can the shaft be removed and the seal replaced with the transmission as is in the vehicle."
I can't get an answer from the local transmission shops so thought I would go through the NCRS.
