Lower Ball Joints 1963 - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I hope to rivet the ball joints to the upper and lower A-arms this evening and have a question. When I removed the old ball joints from the lower A-Arm there was a steering stop bolt holding the rear mount of the ball joint? Is this correct method for securing the lower ball joint? The replacement ball joints have a smaller stop that what I removed.
    Thanks for any Help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    Re: Lower Ball Joints 1963
    Ray-----
    Original ball joints were riveted to the a-arms. Consequently, there was no stop bolt. Stop bolts are a feature of SERVICE ball joint kits, including GM SERVICE ball joint kits.
    If you are actually going to use the bolts for attachment of the new joints, then I would use the stop bolts provided with the kit. There are several different configurations of these bolts depending upon the ball joint kit used.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! Joe
      Ray
      Ray Carney
      • Jack Y.
        • June 30, 2005
        • 76
        Can you tell me what a 'stop bolt' might be?
        Thanks!!
          Jack-----
          It's a bolt with a large, round head that is often found in SERVICE lower ball joint replacement kits. It's designed to serve as a "steering stop". I don't know why most kits include this as the original configuration used rivets for attachment and there was no stop. At least, there was no stop as far as the ball joint installation and area was concerned. All 1964-82 Corvettes had steering linkage stops welded to the lower crossmember. The configuration of the stops changed VERY slightly beginning with the 1978 model year.
          I believe that these stop bolts are completely unnecessary with Corvette ball joint installations. However, they are supplied with the kit and they are "equally incorrect" as the hex head bolt used for the other side of each lower ball joint. So, if one is going to use bolts, it doesn't really hurt anything to use the stop bolts supplied with the kits---they're already there.
          • Jack Y.
            • June 30, 2005
            • 76
            Thanks for the info. Since I have a 63 with original ball joints I will try to take a look at a 64-78 with the stop bolt in place.
            Thanks again!!
              Jack------
              When you get the original ball joints out, I'd like to see a picture of them.
              • Jack Y.
                • June 30, 2005
                • 76
                I will certainly do that. Since the most high tech piece of equipment I have is a dwell meter, I will borrow a camera.
                Thanks for contributing all you(and others) do. I learn alot and don't even have to ask a question!
