68 Gas Pedal Removal - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Gentlemen:
    What is the correct procedure fro removing the pedal from the rod that is mounted to the firewall? I ma trying only to remove and replace the pedal and chrome trim. There is a spring on the reverse whihc keeps tension on the pedal and a pin that secures the actual pedal to the rod and the pin APPEARS to be a press fit but I cannot get it to thread out or move. Any suggestions as my 10 pound sledgehammer will not fit under the dash to get at this pin to "fine tune" it. I thought this would be a quick 5 minute remove and replace task.
    WRONG
    Kurt
  • Geoff C.
    • May 31, 1979
    • 1613
    • Kurt B.
      • July 31, 1996
      • 971
      Thanks Geoffrey, it worked *NM*
