Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 Original BB? - NCRS Discussion Boards
Original BB?
  • Jonesb
    Original BB?
    I just inherited a '66 427 390 hp car. The drive train was recently rebuilt by my father and he checked #'s and everything matched. But I just purchased Noland Adam's book and it says that the BB's had the hood support on the drivers side. This made my heart drop as the hood support on my car is on the passenger side. Were there any BB cars made with the support on the passenger side in '66? Unfortunately in this day and age I realize how easy it is to restamp parts to get them to match. If that is the case the car still has a lot of sentimental value, but it would be nice if it was a matching car.
  • Mark S. Lovejoy
    Re: Original BB?
    My '65 BB has the hood support on the passenger side. I'm reasonably sure the '65 and '66 BBs have the same hood. What page in NA's book are you referring to?
    • Phil B.
      • Today
      Re: Original BB?
      I have a '66 Big Block and you are correct the Hood Support should be on the drivers side. I do not know if there are any exceptions to this. I have read the same comments as you.
      • Bill Stephenson
        Re: Original BB?
        -------Memory is a great thing, if you have it. I think early 66 cars hood supports are on the opposite side. I know if Im wrong I will be corrected!!!........Bill S
        • mike cobine
          Re: Original BB?
          You got the car for free.
          Do you like it?
          Then what difference if it is original or not really matter, unless you are planning to sell your inheritage to make a profit?
          Even if the hood support is on the wrong side, big deal, that is not the absolute final answer on whether it is an original big block or not. Car could have been wrecked. Inner fender replaced. Old support broke and was replaced with the wrong one. The car is 40 YEARS OLD, a hundred things could have happened to account for it, or it simply could have been that way.
          Sentimental overrides original, in terms of personal value. A friend has one of our friend's '61. The guy died in '91 of cancer, and the '61, while mostly original, had several things done to it to make it the way he wanted. The guy who has it kept it that way.
          If I found my '63 convertible, I wouldn't restore it, except to the way it was in '76. Sentimental value, the way I owned the car. Restored would just be like any other.
          If it bothers you so much, move the support. But then, you may screw up the originality, because it just might be original.
          • mike cobine
            Re: Original BB? think about this.
            If someone went to all the trouble to stamp a block, stamp a transmission, put all the big block parts on the car, do you think they would screw up a $50 item that is obvious?
            • Dan A.
              • May 31, 1974
              • 1074
              Very Early Original BB?
              The '65 hood support on the right side carried over to the Very Early Original '66 BB cars.
              Dan
              • Robert T.
                • May 31, 1993
                • 346
                Re: Very Early Original BB?
                Depending on your VIN, you could have a right hand hood mount. Up until approx serial number 3600, right hand hood mounts were used.
                Bt
                • Bryce Jones
                  Ah ha. I'll have to check the serial number when I get home. (I'm at the Dallas NHRA event right now.) Hopefully it is an early number. If not, no big deal though.
                  Thanks everybody.
