'66 40083 FUEL PUMP REBUILD - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I can't seem to get the diaphram dissconnected on my 40083 pump, using the chassis service manual as a guide. Any suggestions would be appreciated...
  • mike mccagh
    Re: '66 40083 FUEL PUMP REBUILD
    grasp the pump in your left hand while pushing the cam-activated lever upwards. grasp the diaphram with mr right hand and twist the diaphram and its shaft outboard(relative to pump's mounting position on engine). it should "pop" right off the lever its attached to. the fun part is re-attaching the diaphram to the lever.good luck, mike
    • Geoff C.
      • May 31, 1979
      • 1613
      Compress Spring and Turn Diaphragm *NM*
      • Rob A.
        • December 1, 1991
        • 2126
        No luck dissconnecting it so far. If I can't get it off, I guess I'll have to remove the brass rivet holding the lever to the housing, but I'd rather not.
        • Rob A.
          • December 1, 1991
          • 2126
          GOT IT APART...THANKS FOR THE INFO... *NM*
