Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Looking for advice regarding Radial Goldline tires for my '66 Coupe. Are there any other vendors that produce these besides Coker? Does anyone have any feedback on Cokers? Also what size would you recommend that will fit stock wheel wells. Thanks
Search Our Tire CollectionSearch for Tires by Size, Sidewall Design, or Year of the VehicleGoodyear Collector SeriesKelsey Tire is the exclusive distributor
Eric....I just purchased a set of P205/75R15 Goldline tires from Diamondback for my 65 coupe. I am totally pleased with them. They look great and balanced fine. I mounted them on a set of American Racing Torq Thrust D wheels. What a look! I wish I knew how to post a pic. Anyway, Diamondback was great to work with and I recommend them. I heard too many complaints about Coker to risk purchasing from them. Just my humble opinion.....Bill B.
