There is a cable that is currently disconnected at the transmission on my 69 BB. It appears that this cable should be connected to the reverse gear rod and then runs up to a junction and connects into the dash area.
Can anyone tell me what this cable is for? The car operates normally and is able to shift into all 4 gears and reverse with no issue. If I shift the car into reverse gear, I can almost get the cable to connect to this rod at the side of the transmission. The rod also has a hole through it so I assume that there should be some kind of cotter- or hair-pin located there....
Please advise, if anyone knows what I am talking about! Thanks!
