If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Jim - that is my understanding for 67 specifically.....I am sure others will verify. As far as I know, there were no engines that restricted sidepipes. Also, no AO Smith cars were BB's in 67 as far as I know......Craig
John, Would that also apply to the 1965 and 1966 AOS big block and small block bodies? I believe it was stated in an earlier post, that only the St. Louis plant had the birdcage tooling, to make the cuts needed for side mount exhaust. Correct? Dave
Jim----
Only combination of '67 base engine with powerglide did not permit side exhaust option. There may have been others in other years. Someone more knowlegeable on them will have to respond.
No AO Smith bodied Corvettes came with side exhaust that I'm aware of.
Kent #6201
Kent 1967 327/300 Convert. w/ Air - Duntoved in 1994 1969 427/435 Coupe - 1 previous owner 2006 Coupe - Driver & Fun Car !!! NCM Founder - Member #718
... N14 side exhaust had no restrictions as to motor or transmission. This was not the situation in 1965, however, as the only small block side exhaust pipe made was 2.5" diameter at the exhaust manifold, and therefore excluded the base engine (manual or auto) and 300hp automatic trans, which used 2" manifolds only.
As there were no automatics or 2" manifolds for '65 L79 (350hp) L76 (365hp) or L78 (425hp), all could order N14.
In 1966 and 1967, N11 (off-road, under car) exhaust was restricted to manual transmissions (3 or 4sp) with any engine. I'm not sure why.
Yes, that's correct - the tooling required wasn't all that exotic (hydraulic nippers with dies and a pair of RH/LH nipper-locating fixtures to position the notches correctly in the sills and sill reinforcements), but Chevrolet chose not to allocate any N14 orders to A.O. Smith - they all went to St. Louis. A.O Smith processed the option on paper, but never built any.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
