Headlight Pivot Lube - NCRS Discussion Boards
  • Mark J.
    • March 1, 1996
    • 254
    I am installing nylon balls on the headlight pivots. What is the best lubricant for the application?
    Mark
  • Stephen L.
    • May 31, 1984
    • 3148
    Headlight Pivot Lube: white lithium *NM*
    • mike mccagh
      Re: Headlight Pivot Lube
      don't think lubricants needed but i used never-seize and they're still free 20 years later. mike
      • Geoff C.
        • May 31, 1979
        • 1613
        • Mark J.
          • March 1, 1996
          • 254
          I've sinned in other ways, too.
          I've replaced many parts with non-GM sources and added aftermarket air conditioning.
          • Geoff C.
            • May 31, 1979
            • 1613
            overspent too; originals are cheaper *NM*
            • Mike Geary
              I've always believed that the balls themselves do NOT rotate and thus only the inner bore needs lube? Correct? I like LubriPlate for this application.
