Re: 1966 BB - NCRS Discussion Boards
Re: 1966 BB
  • William C.
    • May 31, 1975
    • 6037
    Re: 1966 BB
    Or, shorting out on the Radio shield covering the distributor. That will get it VERY hot!
    Bill Clupper #618
    Re: 1966 BB
    Oops - missed the "pink" - thought he meant the solenoid energizing wire. If it's the pink wire from the coil (+) down to the "R" terminal on the solenoid, it will indeed fry if it shorts to ground anywhere inbetween, and will take a bunch of other stuff with it at the same time.
    • B dworsky
      Re: 1966 BB
      Thanks for the help. I guess I'll have to trace it all the way back. Any particular way the Radio shield is grounded other than the support brackets?
        Re: 1966 BB
        The shield is grounded both through its support brackets and through the braid on the plug wires to the valve cover bolts where the braid terminals attach. Check for chafing through the harness wrap where the engine harness turns down behind the pass. side of the block and heads for the starter, and where the spring clamp holds the harness to the starter solenoid.
